Hello I know there have been many , many pano roof issues and discussions with no real results.
Yes I have a crippled pano roof on my new to me 2005. The wind deflector wont move causing the second panel not to open, while the 3rd one works fine.
So I now have an issue with the sun shade not opening.
  Last night I accidentally turned the pano knob the wrong way instead of opening the 3rd pano glass , I opened the second which normally opens to vent and then closes immediately. Well this time it opened to vent ! and then got stuck. I tried the reset which closed the sun shade, then all I could hear is the passenger side motor running and now nothing works. I tried to pull the pano roof fuse to no avail. I used the emergency tool on the driver side and it will open and close the 3rd pano panel, that's when I discovered the passenger side allen emergency gear is cracked so I grabbed a larger allen wrench and was able to close the 2nd panel. Still the rotary switch doesn't work nor  the rocker switch for the sun shade.
Any ideas will help.
Thank you
