I've found the torque spec for the bottom bolt at 63 ft/lbs but have not seen any reference to the top bolts.
I just got a copy of the 996 Workshop Manual. I don't know how current it is. It shows these values.
Engine Mount to body                   M8      23  (17)
Engine Carrier to engine               M10    46  (34)
Engine Mount to engine carrier   M12    85  (63)
I would think that the top bolts were "Engine Mount to body". No?
Item 4 is an M12 nut so it is 63 ft-lb.
Item 3 has no given size but it will be either M8 or M10 - so use the appropriate torque setting.
