I need help with a couple of smog codes: My ODBII reader came up with 1126 and 1133 PD. I can't find an explanation for these. Can anyone help?
:welcomeani:
P1126 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 – Above Limit, or Below Limit
P1133 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Above Limit, or Below Limit
Possible causes:
- Incorrect signal from MAF sensor
- Fuel pressure too high
- Fuel injector fouled
Since you have the same fault on both engine banks - I would suspect a dirty or bad MAF. It would not hurt to check the fuel pressure also.
