Cayenne Instrument Cluster LCD Brightness Repair
Symptom:  Your LCD display inside your instrument cluster is very dim, or was dim before, but now you cannot see anything at all on it.  So you are left with only the analog dials (needles) to rely on, for information.  This prevents you from accessing settings for the car.  This DIY will help you fix this issue.  Most of the time, the issue is a transformer located on the main board of cluster, that becomes defective.  Remedy is to replace it.  Below info will show you every step of the way, fr
