Can anyone tell me what is the easiest way to remove the rear emblem on the deck lid. Also, is there a company out there that makes replacment ones in matching car colors.
01 CAB
Use dental floss and run it back and forth behind the emblem and it sill loosen easily and will not hurt the car. Use your favorite "goo gone" product to clean the residue from the car. Then clean and wax to order. :)
Check with Eric @ www.bumperplugs.com for info on colored emblems
  • 2 years later...
Heating it up a bit with a hair dryer before using the dental floss works wonders. That's how I've taken my badges off.
** note: do not use an actual heat gun - they get too hot and will damage the paint **
