So far I am able to do everything I need on Panamera, using the front car ramps (easy and quick).
When I start doing other maintenance stuff, I wanted to see if there are adapters, which I can get, to put onto car jack or car stand, which will fit exactly into the Panamera lift points.
I saw some DIY stuff, but before I head down that hole, I wanted to see if these adapters can be purchased cheaply.
Thank you.
Thanks.  I did see them, but arent these the actual jack lift points that go into your car, in case they get ruined?
That is my understanding at least.  I am looking for adapters that I can put onto jack lift which will fit into the lift points on the car.
I saw folks making some, but hoping there are some for sale cheap.  Thank you.
