Anyone can recommend a good transmission set - trans filter with seal and trans pan gasket?  Anything else needed other than fluid?
I plan to get the Pentosene trans fluid FFL 3 I believe, which is the original fluid from my reading.  Looking for everything but fluid to replace mine.
Also, there are many kits there which include the transmission pan.  Surely, the pan replacement is not needed, is it?
Thanks.
