Panamera master button switch - buttons replacement
I was trying to find a way to replace switch buttons on Panamera, since one of my master button switches (front driver window button) is missing the chrome trim at the edge if it. I set out to learn how to replace.  Came across the video that shows you how to replace button face itself.  Even though the master switch is removed from the door, one can easily see how this can be done with the switch inside the doors.  Simply unhitch one side of the button and remove the button itself, insert
