I installed the battery and incorrectly connected the battery cabkes to the wrong posts account I put the battery in the compartment reversed. I now have battery/generator lites on  and PSM failure lire engine lite and the key is locked in the ignition. Anyone have any idea what damage was done or what can I do to remove all the lites and release the key from the ignition.
Expand
Most likely, you have burned out one or more circuits by doing this.  I would test the alternator for output, but you have probably either smoked the voltage regulator or a diode or two, which will require replacement.  The PSM is probably a ghost code due to the alternator issue.  You may have also cooked other circuits that have not showed up yet, so be prepared.
