Hello all,
I have done a lot of work to get my 996 going and there are just few things in the way of me being able to smog it and register it. The check engine light came on and it’s showing P1128 and P1130. Any ideas on how to correct those 2 things? Also some minor things I’m experiencing. The passenger window doesn’t go down when opened or when handle is pulled. If I manually push it down it goes down, so it’s trying but not able to pull it down. I tried resetting the levels by holding down the window all the way up and all the way down. Lastly, when I manually lock the door, often times it locks both the driver and passenger doors. But I’ve been stuck at times where it will not lock the passenger door and I’m left in a rut. Then I wake up in the morning and it’s working normally. Any ideas on that? Thank you for reading.
Alex
Please do a search for P1128 and P1130 - they have been covered here many many times.
Likewise for the window not dropping when the door handle is pulled (microswitch).
Worn latching rod in the affected door(s).
