Recently had to get the ABS pump replaced as the control unit had been sitting in water. Following replacement of the pump I am now getting the Brake Proportioning warning appearing on the dash. The independent Specialist I use have checked all the know potential issues to resolve this and there are no fault codes showing, no wiring is showing resistance and everything is dry.  As such they are now at a loss as to where the fault lies. Accordingly would welcome any input from anyone that has experienced similar issues.
