I would like to remove the airbag cover to hand paint the crest. I have read the DIY instructions on removing the steering wheel. Is it possible to remove just the airbag or just the airbag cover? If so, how? (Just pull?)
Is it better/safer/easier to just remove the whole wheel?
You need to remove the air bag to remove the wheel. You do not need to remove the wheel to remove the air bag. Disconnect your battery first. Once you have remove the two Torx 30 screws the air bag will fall out. Do not let it hang from the connector. Then pull off the yellow connector on the back of the air bag.
This is a 3 spoke but a 4 spoke is the same way.
