My bone-stock 2007 997.1 C4S with 71k miles is my daily driver, and the last few days it has a big puff of blueish smoke upon engine startup which then clears in a few seconds. The smoke occurs in the morning (cold start) and also on warm restart. I searched on Google and found that these engines can burn a little oil etc, but strangely enough it hasn't done this for 11 years and 70k miles, so I am thinking something is wrong. Coolant is not low. Car maintained at the dealership, except for oil changes which I do myself every 5000 miles.
Also has P2187/2189, which it had before and I cleared it with Durametric thinking it's the gas cap. Maybe I am imagining it but the exhaust is a little more hoary than before.
Any ideas? Thanks guys.
 I just ran the Durametric on it:
  Bosch Digital Motor Electronics Motronic 7.8.1
Module Identification
Part Number      997.xx
Supplier Part Number      xx
  Current Fault Codes
redsmall.jpg P2187
Oxy. sensor control adapt. RKAT bank 1 range near idle speed
Freeze Frame Information
Fault symptom Limit exceeded
Self test not complete
Fault status fault not present
Warning light off
Fault path num 49920
FLC/HLC state 10
Fault check state 0A
FCM line status 00
FCM output data (mil, svs) 11
Error Path Status 9217
Counter Continuous Error 0
Counter Accumulated Error 256
MIL on counter 1
MIL off counter 3
Clear counter 78
Frequency counter 1
Calculated LOAD value 18 %
Engine coolant temperature 88 °C
Short Term Fuel Trim - Bank 1 13 %
Long Term Fuel Trim - Bank 1 2 %
Short Term Fuel Trim - Bank 2 11 %
Long Term Fuel Trim - Bank 2 2 %
Vehicle speed sensor 0 km/h
Ignition Timing Advance for #1 Cylinder 3 °
Intake Air Temperature 51 °C
Absolute Throttle Position 12 %
Commanded Secondary Air Status 04
Commanded Evaporative Purge 0 %
Barometric Pressure 940 kPa
Relative Throttle Position 1 %
Ambient air temperature 27 °C
Absolute Throttle Position B 12 %
Commanded Throttle Actuator Control 1 %
Long term secondary oxygen sensor fuel trim - Bank 1 0 %
Long term secondary oxygen sensor fuel trim - Bank 2 0 %
Fuel system 1 status 0480
Engine RPM 704 rpm
Air Flow Rate from Mass Air Flow Sensor 4 g/s
Absolute Load Value 48 %
Total operating time (first occurrence) 2563.4 h
Total mileage (first occurrence) 114642 km
redsmall.jpg P2189
Oxy. sensor control adapt. RKAT bank 2 range near idle speed
Warning light off
Fault path num 50176
FLC/HLC state 10
FCM line status 00
MIL on counter 1
MIL off counter 3
Clear counter 78
Frequency counter 1
Engine RPM 704 rpm
redsmall.jpg P2187
Fault symptom open circuit
Warning light off
Fault path num 21248
FLC/HLC state 10
FCM line status 00
FCM output data (mil, svs) 44
Error Path Status 2817
MIL on counter 1
MIL off counter 3
Clear counter 78
Frequency counter 1
Engine RPM 704 rpm
redsmall.jpg P2189
Warning light off
Fault path num 21504
FLC/HLC state 10
FCM line status 00
MIL on counter 1
MIL off counter 3
Clear counter 78
Frequency counter 1
Engine RPM 704 rpm
I would have to agree with Jager, I would start by hooking up a digital manometer to the oil fill cap and reading the crankcase vacuum, which should be no more than 5 inches of water.
  • Like 1
Thank you both you guys are great! Will post an update for the archives once sorted out.
Sent from my Pixel XL using Tapatalk
