I have a 99 996 with 8 way electric seats without lumbar adjustments and the only faults durametric pulls are the ones in the pic. I can't find answers on the forums or in google - Can anyone help?
I would think durametrics would know the difference but could it be pulling the code because I don't have lumbar support?
Thanks in advance
It is indicating that your seat memory module has a memeory problem itself (EEPROM error).  This may be correctable by recoding (requires a PIWIS unit), but if that does not work, you are in the market for a new module.
1 hour ago, PhrogPhlyer said:
Thanks for the reply - Can the pro version durametrics correct it or only piwis?
No.  No Durametric system is capable of coding, that requires the PIWIS.
