So after I took my car for a simple aliments and got new tires I started hearing this kicking noise from the front passenger side. Took it to Firestone and they couldn’t find out what it was. Any ideas? I might have to take it to the dealer but was wondering if that happened to anyone before.
Sent from my iPhone using Tapatalk
were the tires broken in properly?
how many miles on the car?  how long have you had it?  history of front end issues?
could be a defective tire, or front end suspension issues.  control arms?  has the car been tracked?
does the issue occur on a good straight paved road?  are tires properly balanced?
check tire play on a long straight good smooth roadway.  sometimes a bouncing effect can happen if the tires are not properly balanced, and this might not be apparent at 50mph but would be noticeable at 65.
good luck.
  • Like 1
good luck.
It was a loose drop link.
