Just check the threads on the transfer case woes. I'd suggest also visiting rennlist.com - and check the 958 Cayenne subforum. There is an extensive sticky thread there.
All,
I read up on the transfer case issues.  The descriptions seemed to fit.  I bought all the stuff and changed the AFT in the transfer case (54,000 mi).  The job was easy.  At this point a week later, the problem has been successfully corrected.  I will plan to change AFT again in a couple of years.  Thanks,
I would recommend every 10 or 20K miles for the X-fer case fluid change. I assume you utilized the Porsche -63 recommended fluid???
