In doing my water pump I'm also replacing the serpentine belt. I'd like to replace the tensioner pulley/roller as it is lightly grooved, however the roller is no longer listed as a separate item on the 958. There's really no reason to replace the entire bracket so will the 957 roller assembly work (p/n 9A1-102-212-00 )? If not, is there another direct replacement?
