There is a weird front end clicking or thumping sound that usually only occurs after driving slow from a stop.   It only occurs when the accelerator is pressed and disappears when you let off the accelerator.  By accident I found that completely pressing down on the brake pedal will prevent it from happening.  I thought it was brakes but I just replaced pads/rotors & it’s still happening.
Any thoughts?
Any thoughts?
Check for loose brake hardware, brake shield rubbing, debris around or in the caliper...
Sent from my iPhone using Tapatalk
