Getting ready to do my first oil change on my 2017 911/991 C2 .:biggrin: Can anyone recommend the best brand of oil filter, the part number and cost ?  :helpsmilie:They seem to vary in cost from $12 to $35 bucks, different brands and part numbers, on various sites, for the same brand filter ,which I find very confusing ??? Also, is it best to use Mobil 1 0-40 synthetic , or would you recommend another type & weight of oil ? I live in Florida, so Im concerned about 0-40 being to light in the hot summers we have here. Much thanks for this advice, cheers Dave :cheers:
Edited by britdave
Oil and oil filters always tend to start arguments, most of which are totally unfounded.  That said, if you are still running the factory cartridge style oil filter, I would use a Wix/NAPA Gold 57211:
Much better made than the OEM filters which still use glued on end caps that tend to leak. The Wix is embedded in plastic and has a internal support cage as well.  Readily available and most auto part stores.  Even in Florida, you should be fine with a quality full synthetic 5W-40 oil like Gibbs DT40.  Like many other shops, we are no longer fans of M1 product's.
Thanks for the info, I just can't figure out why as to quote you "Like many other shops, we are no longer fans of M1 product's "   :blink: I always thought Mobil 1 was fine , and why do Porsche still use it for a factory fill ? Could please elaborate on why Mobil 1 is not that good ? Also are you sure that " Wix/NAPA Gold 57211" oil filter will fit a 2017 911/991 ?  I tried to find it on the NAPA site and it appears not to fit ? Please advise ?
Thanks a lot, and I will be getting that Wix filter as you suggest if that number is correct ?   Thank U ! :biggrin:
Edited by britdave
I was all set to do it myself on my "new 2017 911/991 gen 2 " , that just turned 3,000 miles. Got all the stuff (oil filter & O ring, new plastic drain plug, and even the special tool to remove and install the new plastic drain plug, THEN I remembered the warranty, and re-setting the on board computer display ! eek.gif
Hence, fearing that issue, I took it to my local Independant Porsche tech here in Daytona, where I use to take my old 996, where I could get a receipt at least. He is very good, and I watched him do it, but realizing I could have easily done it too.
So my questions are : #1. How does Porsche inc feel about the owner who wants to change his own oil, when the car is still under warranty ? I mean, how can you prove it was done ? At least my indy, gave me a dated receipt, showing he was a bonafide Porsche tech, and listed the Mobil 1 0-40 , and Porsche (Mahl) OEM filter .
#2. How does one re-set the onboard computer, ref the "oil change" ?
If something were to happen to the motor, when it's still under warranty, and the owner has been doing all the oil changes, would that not void the warranty ?
Also my indy said the Mobil 1 0-40 is ok , but he recommends either the Mobil 1 5W-40 or "LIQUI MOLY" SAE 5W-40 (German oil) particularly here in Florida ! He also didn't like the plastic oil pan (with no cooling fins to dissipate heat) and this new style 1 1/2 turn plastic drain plug, apparently it's also used on newer VW's and Audi's confused.gif Then there is the air filter issue, were you have to remove the entire rear bumper ! eek.gif
It's quite apparent, that Stuttgart does not want us working on our own cars anymore, and what's with all this plastic stuff soapbox.gif Any advice/input on the latter is much appreciated thumbup.gif Thanks Dave C ( Ponce inlet Florida)
In general, dealers will accept your receipts as proof of service, so keep meticulous records.
Resetting the service alert requires a Porsche specific scan tool such as the PIWIS or Durametric system.
Plastic pans and cam covers are becoming more common with the newer cars.  Your oil is cooled by a separate cooler, so the plastic pan should not bother anything.
Oil is a "hot button" topic, so while I do agree with the suggested 5W-40 weight, I would choose Joe Gibbs DT 40 due to its high levels of ZDDP.
