Hey guys, went out to the car this morning and noticed my brake lights were on and was greeted with a flat battery, anyone had any experience of this?
Cheers!
Sent from my iPhone using Tapatalk
Cheers!
Could be the pedal switch faulty, try disconnecting the plug and see if the BL go off. Don't remove the BL switch unless you have a new one, they are a one time fit affair apparently. Other issues can be the rear comfort control module faults.
Get the battery charged and read the fault codes I guess would be a start also.
