Hello All,
I changed out the old dried out valve cover gasket on my 2006 Cayenne S.   I took some pictures of the cam, and noticed some interesting wear around the tip of the cam lobe. Would like some input or comments regarding the wear. Does this seem normal for a 2006 Cayenne with 195K miles?
Thanks in advanced...
Your lobe wear does not look out of the ordinary.  Cams are made from cast  iron, and develop a shine or wear pattern over time; as long as there is not a ton of ferrous grit in the sump or oil filter, you are good to go.
