I have a 2004 Porsche Cayenne Turbo with this code. I am told it is indicating "excessive slippage" internal to the torque converter. Is there somebody who can give me some advice? We are still troubleshooting.
Sent from my iPad using Tapatalk
:welcomeani:
You can get this fault code if the ATF is the wrong spec or if the ATF cooler is blocked.
If not that you may have to replace the torque converter.
Has the transmission been serviced recently? As Loren said, could be wrong fluid, could also be the fluid level is too low. How many Kilometers on it? Possibly the valve body. A specialist  should be able to troubleshoot the Torque converter and if it's locking up properly or intermittent.
Hi, I have been flushing the transmission, change ATF oil, new valve body, new transmission ECU and the wiering inside the transmission. Everyting is done at my Porsche dealer. I have also change the MAF and TPS. My car has run 127 000 kilometers. I have spend allot Off Money and they can't find the problem.
1 hour ago, kikka said:
Anyone?
Exactly what Loren noted above, you probably need a new converter:
P1192 - Torque Converter Lock-Up Clutch: Mechanical Malfunction
Possible Symptoms
  • Torque Converter Lock-Up Clutch slipping
Possible Causes
  • Torque Converter Lock-Up Clutch faulty
  • Valve Body faulty
  • Internal Failure in Transmission
Possible Solutions
  • Check Torque Converter Lock-Up Clutch Slip
Possible Symptoms
Possible Causes
  • Valve Body faulty
Possible Solutions
Hi, I gave change the converter and the problem is still there...
In the original diagnostic tree, there were three possible causes:
Possible Causes
  • Valve Body faulty
The convert was first because it was the most probable, you now need to look at the other possibles in order of priority.
Possible Causes
  • Valve Body faulty
Hi, I have change the Valve Body too and the problem is still there..
