I just bought a 2010 Cayenne Base and the Parking Sensors are delivering false results. (See photos)
It has been doing this for a few days now after a very cold spell in central NY. I just washed the car in hopes that it was just some debris in the sensor, but this is not the case. Any suggestions other than turning the sensors off?
:welcomeani:
If you have Durametric you can run a fault check and see which sensor(s) or whether they are all reading on.
Usually, it is just one or two sensors - so you just replace the bad ones.
