Can someone validate whether or not the dealer ACTUALLY has to install the PCM 3.0 Nav Update?  Unless there is some voodoo that they have to do with the PIWIS, why do they need 2 hrs of labor to insert a disc and press "enter" a few times??  Seems a waste if you can read directions...  Thanks for any help.
The navigation system update is done by DVDs in the head unit.  It depends on the initial software version you have, but there are up to 3 updates required before the latest maps will run.  The software updates can take up to an hour to run.  (Note that after the updates, old map data will not run).  After the system is updated, an Activation Code is entered using PIWIS2 or PIWIS3.   (The Activation Code is based on the VIN, and comes from the Porsche online PIWIS system).  Then the map data is loaded from DVDs.  On PCM3.0 it takes around 40 minutes per map DVD.  In Europe there are 4 DVDs.  PCM3.1 updates are quicker, as they have a faster DVD drive.
  • Upvote 2
