I've got a deposit on this 2002 Cab 4. I already know there are quite a few issues and most everyone on here would advise against buying it, but I'm a bit of a risk taker when it comes to buying cars. My last two Porsche's was a 2007 Boxster S with a flood title and a 2011 Cayman S with 160,000 miles and I did very well with both of them. There's an entertaining read about the Cayman S on here if interested search Would you buy a well taken care of Cayman S w/160K. Also I'm no longer a "CoupesOnly" driver, living in Florida has changed that.
I've got quite a bit of info from the carfax. I know about the accidents, rebuilt title and mileage discrepancy. I've also called every place that serviced it. It's had 2 major services and the people that owned it were not shy about spending money on it. Unfortunately, I could not find a history of the IMS being updated. But with all the dealers and repair shops I called on this 911 and a few others, none of them recommend updating the IMS at this point. They all said it's a very small percentage and that when they do fail it's way before reaching 100k miles.
My hope is to find someone who owned or knows about this 911 and or if someone near by would be willing to go take a look at it for me.
https://www.cargurus.com/Cars/invent...ting=187314312
That could be a very questionable wager; we have seen them fail with well over 100K miles on them, and being a 2002, it is a single row IMS, which has always been the most questionable.
That could be a very questionable wager; we have seen them fail with well over 100K miles on them, and being a 2002, it is a single rowIMS, which has always been the most questionable.
I agree and will most likely get it done.
Good.  You will have piece of mind.
i did my IMS retrofit at 35k, and wii do it again at approx 70k.
Only real consideration is whether to install the pressure-fed "solution."  Costs more but likely worth it.  Good opinions on forum about this choice.
Best to do clutch and RMS at same.
But for sure get the IMS done.  Cheers,
