any help on taking off this cover? i got the screws off, but don't know how to lift it off, or if there is a catch.
thanks a lot!
Pull the light out with your fingers and pull the connector if you have not already done so. Below the light is a round plastic thing with a slot that you need to turn. Then the cover lifts out, but you need to hold the rubber seal out of the way.
thanks a lot!
it worked perfect!
thanks for your help, toolpants!!
:D
