‘05 Cab. Washed the car and backing out of the drive I get both PSM and ABS fail lights. It clears if you restart the car but comes back as soon as you brake. Any ideas? Thanks.
Sent from my iPhone using Tapatalk
996/997 cars are well known for their intermittent electrical issues after washing.  Run the car and drive it for a bit around the neighborhood to dry everything out; if it still does it after that, you need to scan for codes.
Cabs are quite well known for holding water behind the rear seats, this gets into the electrics, i have pasted a very useful thread below, but if you search on here a little further it is pretty much explained in other threads too.
Took it by the shop and looks like it’s the brake switch. I’ll search for the fix when I get to a computer. Thanks guys.
