I have 2 - 2001 Boxster S’s. One has Porsche Stability Management (PSM) system (replaces traction control), one does not. I want to swap it over to the other car. Is this a possible option?
Edited by Zky Captain
Correction
Depends upon how much work you are ready to do.  The PSM system is a complex network of pumps, hydraulic lines, sensors, and control electronics, all of which will need to be swapped, flushed and bled,  and then programmed in the final vehicle.  Do able? Yes.  Worth the effort and expense?  That is up to you.......
