The check engine light turned on when I was driving on the highway yesterday (2001 C2 Cab, 16K miles, one week after installing PSE exhaust). Stopped by my mechanic and he pulled one code out - P1128, which translates to "Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold".
My mechanic reset the light and sent me on my way to see if it recurs. Any one have any experience with this (or suggestions)?
P1128 Oxygen Sensing Adaptation Area 2 (Cylinders 1 - 3) - Rich Threshold
Fault condition: Fuel/air mixture is so lean that sensing has reached its rich threshold.
Translation: Oxygen sensing at rich threshold is stored in the memory, this means that the fuel/air mixture is too lean.
Air leaks ahead of the oxygen sensors can lead to a fault in adaptation also check exhaust system for leaks.
Fault area:
- Intake air system leaking.
- Fuel pressure too low.
- Volume supply of fuel pump too low.
- Fuel injectors fouled.
Start by checking for air or exhaust leaks - including the gas cap, oil filler cap, all hoses etc., etc.
