I have a 2003 996 cab with 114k miles. The clutch has begun to slip if I drive with any gusto. I can granny it around without slippage. Am I looking at a clutch replacement? If so, any estimates on total cost? I can turn a wrench but no way do I have the time or skill to tackle something of this magnitude. Any advice greatly appreciated. Thank you.
Sent from my SM-G925V using Tapatalk
Labor rates vary with geography, so you will have to check them locally.  Figure on 4-6 hours, plus parts.
A full clutch kit (disc, pressure plate, throw out bearing) should retail in the $400-500, assuming your dual mass flywheel is still good.  If it isn't, add $1K.
You should update the RMS while doing this, and it is also a great opportunity to retrofit the IMS while it is apart.
  • Like 2
