Hello All,
I am in the process of changing the starter motor on 2006 Cayenne S.  I tried to be really careful, but the rear vac line where you pinch, broke off. I can't seem to fine where the other end goes.  I was hoping someone can tell me at where the other end is suppose to attach to.
I think I found it. It looks like part of the venturi hose.  I am gonna just patch for now, and order a new one.  BTW.  Getting the starter out and in wasn't too bad.  I loosen the back plastic support for the three coolant pipes.  I had my daughter pry up just a few mms which was just enough for the starter to clear.
