check the search engine.  I've read there somewhere that the entire cluster might have to be replaced.
The lights I believe are individually changeable.
someone on the forum will surely know all about this.
good luck.
  On 10/11/2017 at 11:18 PM, Byronnevada said:
The squiggle on the MPH is growing everyday. I see some Replacement LCDs on Amazon. Has anybody tried to do this repair on their own?
I repaired mine. It was actually easy once I got the confidence to crack it open. You need a special tool ($8 and a soldering iron that will fit it) to heat the ribbon connector and peel the old one off and stick the new. I ended up replacing all three LCDs since a second one went bad and I ended up wanting all three to have the same contrast.
I can now do the whole job in just a few minutes, but the first time took me hours. I’d say, send the whole cluster off to a repair service to get fixed if you value your time more than I do, or don’t like to take risks.
