I cant seem to access my bleeder valve in my 2008 boxter to flush the coolant do you need to take the oil and coolant hoses off the back of the plastic bracket?  ive taken out 3 nuts and 3 tourque screws and bracket will not come out help!
Just found out there Is Not a bleeder valve for the 2008 boxter..... After wasting a whole day looking for it buying a new floor jack and the coolant... this is not a job for the DIY mechanic.. you need a special tool to suck all the old coolant out and and an air compressor.  Pissed at pelican parts lol.
  • 2 years later...
There is most definitely a coolant valve on the 2008 Boxsters. It is located under the top engine cover on the passanger side just in front of the coolant overflow tank.
[Only resurrecting this because it is one of the first google results for "987 bleeder valve" and contains incorrect information]
