Does hitting the rev limiter under acceleration get logged as an overrev in the ECU? I'm thinking not because the rev limiter should prevent the overrev but ask for confirmation from others. Am I correct in thinking that an overrev should only occur and be logged if a downshift causes an overrev condition?
Thanks.
Search is your friend. One time I hit the rev limiter by waiting a fraction too long to upshift.  Upon arriving home I immediately checked for overrevs and there were ignitions in ranges 1 and 2.
Thanks.
Welcome to RennTech:welcomeani:
Anytime you hit the limiter, it is recorded in the DME, regardless of the circumstances.
