Greetings everyone,
(This is a noob question! However, since I have not yet found a decisive answer I turn to the community. Please direct me to the correct post, if it exists! )
Carrera 4S 2008, 997.1 was put on hazards for 24 hours.
Afterwards, it appeared the battery was dead as hazards had gone off. Remote unlock was non-functional.
I plugged in the CTEK trickle charger ("car mode": 14,4V / 3,3 A) in the cigarette igniter. The car immediately exhibited the following behaviors:
-hazards lights flickering regularly, at approximately 3-4 Hz
-hazard button flickering at the same pace.
-Sport chrono's hands waving around erratically
I left the car in that state for 5-7 hours. After that period, I pressed the hazard button and the flickering stopped. I assumed the car was now charging.
Coming back to it 10 hours later, I unplugged the trickle charger; the battery was still dead.
I replugged the trickle charger, on car mode, and the flickering resumed. I gave it 12 hours.
This morning, I observed the flickering was still on. I tried to turn on the engine, to no avail. The car key remained locked in the ignition.
I could not pop the hood in order to obtain a voltage measurement from the battery's poles.
My hypothesis is that the electrical system is in a faulty state and needs a hard reset, before charging can occur. Perhaps I also need a different piece of equipment.
Any help... HELPS!
  On 9/28/2017 at 4:39 PM, Gee_Ell said:
Greetings everyone,
Any help... HELPS!
Expand
It is a common misconception that a battery maintainer is capable of recharging a severely discharged battery.  In reality, the maintainer simply cannot produce the current (read amps) necessary to recharge the battery, if it can be recharged.  Many times, a deeply discharged flooded cell battery simply cannot recover and will not take a charge.
Try recharging the battery on a real charger capable of 20 amps or more.  If it does not recover, replace it.
As I mentioned, one with at least 20 Amps out put; in the shop we use a commercial charger that can throw over 100 Amps when needed.  I would look for one with what is called "smart charging", which simply means it uses modern electronics and software to control the charge cycle.
