Hello people,
I have a few questions, oil level on the Cayenne S should be measured when cold or 65c oil temperature? Because I measured it in cold and its in the middle of the dipstick and with the hot oil its full. And also my A/C works perfectly in every fan speed except on 1. It works on 1 only if I put it on another speed and after a few seconds lower it to one. I hear the blower motor making like a squeak sound.
56 minutes ago, Cayenne1992 said:
Hello people,
The blower can be removed cleaned up and lubricated and reinstalled to alleviate that issue or you can replace with new. Removal of glove box is required. Pelican has a diy for that.
Oil level measure when engine has been resting for 10 mins, hot and cold level will vary alittle but not a lot. Keeping oil between 1/2 and 3/4 is ideal.
Removal of glove box NOT required. It's a 10 minute job swapping out the blower. 1 screw holds the lower dash kick panel. Bam there's the blower housing. 7 screws later there's the blower. Clean it. Replace it. Your call. Easy peasy.
2009 Cayenne S
160,000mi
Chicago
