Hello everybody,
I am looking for the setting values for the wheel alignment on a Cayenne GTS 9PA1 (957) with air suspension.
MY2010 (2009-12)
Thanks in advance.
Edited by 12runner
original 21"
need wheel alignment values:
FRONT
Caster
Camber
individual Toe
total Toe
REAR
Camber
individual Toe
total Toe
Edited by 12runner
Ride height
Front: 190 +-10 mm (From wheel contact area to bottom edge suspension subframe wheel center)
Rear: 236 +-10 mm (From wheel contact area to bottom edge suspension subframe wheel center)
thanks Loren,
these are the values for normal air suspension (springs),
but the GTS is lower, ca. -20m front  ca.-10mm rear, so the values should be different?
1 hour ago, 12runner said:
thanks Loren,
Yes, ride height will be different (Likely 20 mm lower front and 10 mm lower rear).
Verbatim from my (2011 version) Porsche Cayenne factory service manual...
WM 4495TW ADJUSTMENT VALUES FOR SUSPENSION ALIGNMENT (CAYENNE, CAYENNE GTS, CAYENNE S HYBRID, CAYENNE S E, CAYENNE TURBO) > ADJUSTMENT VALUES FOR SUSPENSION ALIGNMENT > WHEEL ALIGNMENT VALUES, AIR SPRINGS
