Coolant expansion tank replacement
I recently had the opportunity (read need) to replace the coolant expansion tank on my '06 CS Titanium due to the seal leaking.  While the DIY write-up on Pelican Parts is certainly adequate I think they have you do more than necessary.  So, below are the steps I took to replace mine. Tools needed (may not be all inclusive as I'm doing this from memory): 12mm triple square driver, T30 & T15 torx bits, 16mm (or 5/8") socket, couple of extensions, blade screwdriver 1. Remove the beauty cov
