I changed driver side cable
Got the timing from left to right off somehow not by much
The tonneau cover is just slightly opened on passenger side
I'm pretty sure you meant the soft top or the canvas top.  A tonneau cover looks like the photo below.
The top transmissions can be adjusted with a cordless drill (set to a low torque setting). Here is a link by 1sChoir explaining the procedure in greater detail. These usually need to be readjusted after replacing a bad transmission or a replacement of a broken (or stretched) transmission cable.
PRESS HERE for Adjusting Soft Top Transmission
Edited by kbrandsma
