The lights on the interior door panels won't work . Checked setting on overhead also checked fuses. Seems weird they would both stop working at same time. Anyone have any suggestions as to what the problem might be....Thanks
Ahsai the window drops when you open the door then returns to fully up when door is closed. In fact everything else seems to work fine
Edited by Brian Zaniboni
Spelling
Do your vanity mirror lights work? They are powered off from the same circuit as the door panel lights. The door panel lights are directly controlled by the alarm module. Can't explain why both went out. Have you checked the bulbs?
Use a soft plastic spatula to pry it up carefully on the rear section of the cover.
Edited by Ahsai
You got a strange problem and it's not the fuses (B8, E1, E4) because as I tried to explain before, the vanity lights are on the same circuit as the door panel lights.
The orientation light (LED) above the inside door latch is also from the same circuit. Are those working? They may be very dim and can only be seem in total darkness.
Any chance someone had the interior door panels off and just forgot to plug the lights back in?  You'll know immediately when you pry the lenses out.
Good point re connectors.  sometimes things do come loose.
I doubt that would happen in both doors at the same time, unless the car had been apart for restoration or painting or something that required both door panels to be removed.
I'm not sure that's likely.
Only other possibility is that the fuses were rewired to accommodate a radar detector or other accessory and were not properly remarked.
Good luck.
