I need to replace Fan cooling  relays. Part number is 141-951-253-B. It takes several days to get them shipped hence this question: Is there a generic one I can buy from a local Auto Zone that is compatible? if so what should I be asking for in terms of specs for the relay?
I would say yes, I guess it's a normally closed relay for so many amps which can be duplicated easily enough.  However, the Porsche relay might have specific mounting tabs that the generic relay will not have.  Most of the above information will be found on the replay.
