Remove the panel below the box, near the footwell, one screw, I think. Remove the aluminum trim to the right of the latch button, it just pops off. The top and bottom screws are then exposed. It is less work if the box is not fully removed. Otherwise the heat tube and latch mechanism cable will also need to be removed.
Yes, there are places back there to fit stuff.
