Ok so just changed my stater motor (What a pig of a job)
Everything back together but now the car is idling hi, Looking at the photo you can see the flap is open a bit and the cable pulley is  not resting on the stop. Should it be?
Can anyone see what the problem is?
Undo the throttle cable from the TB and carefully but with firmness give it a hard pull.  The back of the throttle cable snaps into the black plastic flucrum piece, and  both need to be snapped into place on the TB.  Been there....done that.
