The 996 C4S calls for part # 996 624 127 00 for the auxiliary fan. (left front radiator)
Will the fan for the C4, part #996 624 135 00, work?
Not positive, but I don't think so...  P/N's don't lie...  I replaced my radiators on a C4S and they're different than a narrow body car. Also replaced the fan which has different mounting points.
Mitch
Thanks for the info. The motor on mine is bad and the resistor is good.
I was hoping the motor was the same size and the difference was only the 3 speed resistor for the C4S vs 2 speed resistor for the C4
I did install the the the less expensive C4 fan (996 624 135 00) in the C4S with the following results.
1. Fan is the same diameter and size.
2. Motor diameter and flanges are the same size and will bolt into radiator shroud.
3. Offset of motor flanges are different, moves the fan 1/4 inch closer to radiator.
4. Changed style rubber grommets in shroud to gain 1/8 more clearance, but fan is still closer to the radiator than the stock fan.
I'll let you know if the spacing gives me any problems.
