I have a 2010 panamera turbo; did not come from factory with launch control; is it possible to add the launch control mode and not sure if you would need an entire different transmission or its an additional part that is included.
I believe the engine would be the same without any modifications.
Also does anyone have any specs of a 0-60 time with the launch control compared to not having that option
Thank you
  • 3 months later...
Here is a link to a sport plus add on.
https://www.suncoastparts.com/product/970SMS.html
Compatibility: Fits 2009-2016 Panamera models with PCM 3.1”
I think Sport Plus /Launch Control get you about .2 sec from ~4.0 to ~3.8
Another feature of Sport Plus with the turbos Is that you can get over boost for about 10 seconds which can boost the max torque ~10% from 516 ft-lbs to 568.
Jet pack for passing.
Edited by Fulwild
Removed irrelevant info
perfect; thanks so much for the info; going to check it out further; i did read the link that stated the below; i have a flashed ecu file with approx 620 hp; do you think it would require a new flash file if the below is in reference to the dealer having to flash the ecu; not sure i understand the beloe
Software License: We submit your software coding to Porsche, and your installing dealer can upload this information from the Porsche network.
  • 4 weeks later...
Just out of curiosity could you post total cost so others considering this will have the info. I think its a better track to sport plus than the sport chrono pack as original equipment but that could be because I have never found a use for the chrono.
Edited by Fulwild
