Hi can someone help me with the coding and configuration of various modules  on a Porsche boxter convertable 987 2006 2.7,  I replaced a rear control unit which was completely damaged from water , car suffered from various symptoms most of which are working now, I am trying to code the rear control unit and in the process Initially may have put wrong coding to other units . Is there a table or list for the various modules coding (what options should be ) for a uk spec, the roof is inoperable  also I have psm/abs failure on instrument cluster and code's show incorrect version coding, the rear control unit was installed with non cabriolet roof, but this did not make any difference, any help much appreciated.
