Ok, so we're talking about a 17-18 year old key fob (Even at their best, they never worked at 200ft. like a Toyota fob). There's a good chance it just may be plain worn out... Keeping that in mind, a fresh battery is the first thing to start with. It seems like you changed the battery in at least your #1 fob - did you change both? If yes, is there any difference in how they work? If not, there is the possibility that the switch (button) is worn/damaged, or perhaps the pc board in the fob is damaged (sometimes the solder joints will crack from flexing many thousands of times). In many cases opening up the fob and just touching all the solder joints with a hot soldering iron is an easy fix. Short of such a DIY your options are limited to getting a new fob(s) and having them programed by a dealer $$$
  • Like 1
