Hello All,
I have a 1999 Boxster. I recently had fault code 34 for the Central Locking unit. I switched out the interior sensor and now I am getting fault code 22. Any help on this? I'm not sure what the difference is between the two codes.
Fault 34 Passenger compartment monitoring sensor -- Short circuit to B+ or faulty.
Fault 22 Passenger compartment monitoring sensor -- Short circuit to ground.
Check for damaged wires or connectors.
