MY99 996 carrera4 US, the abs/psm lights come on sometimes as i am driving. they go off everytime the car is restarted and then they appear after a short (ten minutes) time while the car is in motion. A while ago they would come on when I adjusted the steering wheel height adjustment with the lever, however it went off when the car was restarted. I don't know if there is a relation here.
can some help with any clues?
thank you
My 2001 C4 did that, exactly, just after leaving Daytona in Feb.
Turned out to be a bad cell in the battery. The only other indication I had was that the engine seemed to crank a little more slowly than I remembered but always fired off.
