Hi all,
I hope you can help me.
My transmission is making a weird noise.  My IMS/RMS was replaced at 96K miles and I'm now at 106K.
Here's a video of the problem:
Thank you.
A common source of that type of noise is the muffler heat shields.
Check for loose muffler heat shields or if they are touching either the muffler or the car body.
Thanks! I lifted her to see and all looks fine with the exhaust and heat shielding. Any other thoughts? Pinion bearing, worn transmission mount?
I hope there is oil in the gear box, just take a look you never know.
